Nah I wish. It does it after it's been running for about 5-10 mins. And it doesn't stop (that I've noticed). The smoke clears up above around 1000-1100 rpm.Im betting it only does it when cold right?
You thinking FICM Dave? That was my thought but unless it is really bad I would expect it to go away when warm and be worse when cold.Im betting it only does it when cold right?
I am leaning towards a fueling issue, but Shawn could be right too.
Does it smell like fuel?. Pull the intake tube from the turbo and check the shaft for play.
Pull codes Im betting you see P0611 or several injector codes. Your FICM is out.Ok so to make matters worse my truck died while cruising down the road today. I was only goin about 30 and it just randomly died. Now it wont start up. Im supposed to be borrowing a friends snapon scanner this weekend to see if itll pull anything useful up. Wonder whats goin on??
Add some Rev X to your truck.I agree with Dave. Sounds like your Ficm just let the smoke out.
FWIW my truck smokes like that when its cold. It clears up after ~ 2 min of running though.
Needs injectors. Mesh inlet screens are beginning to fall into the injector. Oh well :crazy:Add some Rev X to your truck.
