So I’ve been searching and reading through a whole bunch of posts here for the past 2 hours and none of them seem quite to match the issue I have with my 6.0L. I have a 2007 F250 with 68K miles stock with only a Magna Flow exaust and K&N filter and a couple of months ago it started smoking white smoke. I haven’t driven the truck much because I’m afraid to do more damage (I’m glad I own a motorcycle and live in California). The thing of it is it has no codes and the smoke is intermittent with no real pattern. Sometimes it smokes when it’s cold and sometimes it won’t regardless of outside temperature. It will smoke a little or a whole bunch or sometimes not at all. The power seems fine even when it is smoking although occasionally has a rough start when it's cold. It always goes away once the engine is warm. It does (and has for a while even before the smoke) loose coolant through the cap of the degas. I’m afraid it's the head gasket and haven’t taking it in yet because of it since I been told how much it will cost to fix. Is there a chance that it’s not the head gasket and I won’t have to spend thousands to fix it? Any advice on what else it could be?
Thank you.
Thank you.
