1 - 15 of 15 Posts
Hey guys, I've been stalking for a while, but this is my first post.
I just bought my 96 F-250 a couple weeks ago. It came with the 4" MBRP turbo-back, DIY intake, and a BB in the FPR. I just installed VDO gauges on the A-pillar (less than $200 for pillar pod, boost gauge and pyro gauge!).
Anyways, enough history on the truck, I just tried out a handfull of resistors the other day and I couldn't belive the difference it made! I felt the truck was too sluggish before, it spooled slowly and was gutless unless it was under good boost. The highest EGT's i could see without a resistor in was about 650 (LONG uphill pull on freeway)
I tried the 10K and knocked 3 seconds off my 0-60 time! Next was the 5.6K, but it must be a bit too much, because it starts to fall off at the end of 3rd-5th. I've got an 8.6 in now and it still pulls all the way thru the gears. took another second off 0-60 time going from 10k to 8.6K. Now I can get EGTs up to about 850 after about 15-20 seconds of WOT uphill pull in 5th gear (about 22psi)
What do you guys think is making my truck run out of Ooommpph up top with the 5.6K? HPOP? Fuel pressure? Injectors?
:icon_ford::icon_ford:Thanks for any advice, and I LOVE THIS SITE!!! :icon_ford::icon_ford:
-HOSS-
First off, welcome to the Org. Second, glad to hear that the resistor mod is helpin ya out.:thumb:
I'm not sure exactly why your truck would fall off the power with the 5.6K resistor in. As for the HPOP, installing a SD 17* HPOP wouldn't hurt. Another little boost with power. (the HPOP is what provides the oil to inject the fuel through the injectors)
mike
The smaller resistor demands more icp, oil than the pump can make so it falls on its face.
Mark
SuperDuty73, Ok. So since the lower resistor demands more oil pressure, would it work if the stock OBS HPOP was replaced with a 17* SD HPOP? Or would it need something more like an Adrenaline HPOP?
mike
At least a 17° pump but it depends how much it will cost you. If you get it new you might as well buy an adrenaline pump, but used the 17° pumps are sometimes cheap.
The one good thing I like is the adrenaline is a great pump, improves power and MPG. I cant wait until I have the $$ to get one myself.
Mark
Just installed a 10K potentiometer with a 1.5K resistor inline (so it can only go as low as 1.5K, not zero). Got it ran into the cab. Now I can crank it up, and watch the coal roll out the back, lol. Still can only get about halfway up the scale (8-7Kish) when it runs out of fuel on top end. (probably because of the HPOP as already mentioned) kinda handy tho, forget those $300 6pos chips, I'll take my $3 infinite position "chip" from radio shack, lol.
if you think those little resistors wake your truck up,wait till you try a chip.i used to play the resistor mod games until i got a chip.i wont ever go back because its a night and day difference.a chipped obs will leave you in the rear view mirror.i suggest you invest in performance chip.what was your 0-60 time? :icon_ford:
if you think those little resistors wake your truck up,wait till you try a chip.i used to play the resistor mod games,until i got a chip.i wont ever go back,its night and day difference.a chipped obs will leave you in the rear view mirror.i suggest you invest in one.what was your 0-60 time? :icon_ford:
Real slow. With my cellphone stopwatch sitting in my gauge cluster, watching the speedo road and stopwatch while shifting, i think I bested 11.5-12 seconds. Bested 15.9 stock.
Is that in the right ballpark?
P.S. I will get a chip, but do you think I should mess with the HPOP first? Can only afford one or the other for a little while.
no hpop work unless its not working properly.buy 3inch down pipe and slap that chip in there.i think you have gauges already so thats taken care of already.how do you take off with your truck/what gear?
I think I have an aftermarket downpipe. He said it was an MBRP 4" Turbo Back. This looks aftermarket, but don't look to be 4" maybe its an MBRP 3" downpipe?? :dunno: Anybody know? :confused: Deffinately getting a chip once I get my finances a little more straightened out from buyin' this pig, lol.
I started out in first, with a quick clutch slip to spool the hair-dryer up a little, second seems like it takes way to long to build boost, so I think 1st works out to be quicker, even with the shift time.
Anyone have advice on launching one of these things better?
looks like a 3" down pipe in the picture so you should be good.i cant launch mine good either.i normally start in 2nd because its a longer gear. 1st gear is done to quick in my opinion.i dont slip the clutch anymore to race,to expensive.lets see a pic of that truck.:icon_ford:
Discussion Starter #12 (Edited)
looks good,never seen one with racing stripes like that.
1 - 15 of 15 Posts
