1 - 20 of 23 Posts
Only 9k miles and the plastic rocker arm broke off, fell down and blew the motor. Ford says the new motor will be in next week for the change out. Apparently the rocker arm is a PROBLEM. Heads Up!! Let your WARRANTY person know if they already don't.
WOW that really sucks... sorry to hear about that.. how many motors have you gone through?? and are you using it as a pulling truck or just a daily driver?
is it a 6.0? lol
Plastic Rocker Arm?
Wait, Ford is putting some moveable Plastic drivetrain parts in a Diesel motor? Whats up wit dat?
Infidel
The plastic rocker arm broke off, fell down and blew the motor. Ford says the new motor will be in next week for the change out. Apparently the rocker arm is a PROBLEM. Heads Up!! Let your WARRANTY person know if they already don't.
You have got to be kidding me!!!!!! A frickin plastic piece on an internal in a diesel engine? What crack smoking rocket scientist thought that would be a good idea?
Sorry to hear that you are down a vehicle right now. Hope it gets fixed right and back to you ASAP.
Craig
i think i need proof on the plastic rocker arm statement.
hope everything works out. mine might need a motor cause of something weird too
International Threat
Cleaned this one up a bit - don't bash this mbr please!
Infidel
Bashing a member when their rig is broke???? Isn't that like getting kicked when your down? That's just not right.
So did International really use a plastic piece on the rocker arm?
Craig
What u talkin bout willis
dang man that sucks sry to hear that
There are Plastic Valve Covers on the 3.8L mustang in 83. And they do warp and they are exposed to the air cooling but I fixed it with a new gasket. My VW Diesel has a Plastic deflector inside the valve covers and it survived 300K miles.
My Chevrolet 6.5L has plastic pieces that hold the rocker arms on. If one breaks off the rocker arm will probably stop working completely. I would guess if an exhaust valve rocker broke it could be devastating.
now if this is true how would they go about fixing it....but another motor in there with pieces made my fisher price..sry about the ride man
The rocker arm is not made of plastic. The retainer is plastic same as the 6.0. This part has never been a problem in the 6.0 so why change it? The steel rocker arms were breaking in the 6.0s not the retainers.
Is there really plastic rocker arms in this motor? I can't see them lasting to long with the expansion and contraction from the heat. That part won't last as it will get brittle from the heat. Hope there is a recall for this soon.
my guess is that they are not plastic, and if there are plastic parts in there, I can only hope they do not play an important role.
it would be international's fault for the bad design with plastic.
I think ford has something to do with asking them to save a few bucks somewhere.
1 - 20 of 23 Posts
