I have a ‘05 and the blinkers (both sides) will flash for a little while but then go to a steady on when I select the corresponding side. I did a quick search and all the threads I see are from a while ago and so a lot of the links are dead. I saw on one that this was covered by a recall, but the truck has been to a Ford dealer in the past 6 months so I am guessing that it doesn’t have an active recall on it. I want to say that the relay is fine since it works sometimes and the selector in the column sounds like the culprit. All the bulbs work and I don’t want to throw parts at it and hope that I get the right one before I go broke. Is there a way to test the selector switch?
