I am all for trying to save money. But when it comes to my fluid systems, I run what I feel is the best I can put in them. System failures due to sub par products especially in a diesel are to expensive. I believe that you usually you get what you pay for. I agree that Amsoil products are expensive, but purchasing them as a preffered customer the prices aren't that different than purchasing a quality synthetic off the shelf of your local parts house. I admit shipping costs are added, so that does raise the price. But if you use them to their full benefit and do the oil analysis testing to determine your drain intervals, you should be able to save money in the long run. If you change trucks every 2 or 3 years, it isn't worth the added cost.Thanks Drew. You and I both know that some companies make more profit off their products than others. So I was trying to find an alternative source for the 2 micron by-pass filter that would fit my Amsoil filter head assembly. I like Amsoil products, however they are a bit expensive and I am not convinced the lubricants are that much different than the major oil companies. After all I would think the company with the most money have the biggest labratories.
Well said. Any standard filter will spin-on the housing, but it will not operate as designed. Preferred customer is the way to go, wholesale pricing vs. retail pricing. As is the case most of the time you get what you pay for.I am all for trying to save money. But when it comes to my fluid systems, I run what I feel is the best I can put in them. System failures due to sub par products especially in a diesel are to expensive. I believe that you usually you get what you pay for. I agree that Amsoil products are expensive, but purchasing them as a preffered customer the prices aren't that different than purchasing a quality synthetic off the shelf of your local parts house. I admit shipping costs are added, so that does raise the price. But if you use them to their full benefit and do the oil analysis testing to determine your drain intervals, you should be able to save money in the long run. If you change trucks every 2 or 3 years, it isn't worth the added cost.
Cheers,
Brew
