1 - 7 of 7 Posts
Anybody know of a chip that will let you adjust the altitude that your truck is at? I have a 6.0 diesel and was told that all diesels are set at sea level - can get an increase in fuel efficiency and savings if you adjust to the altitude you are at.
Any suggestions?
:dunno::dunno::dunno::dunno:
I always thought they adjusted themselves. I know mine ran great going back and forth across the Cont Divide and throughout Yellowstone.:dunno::dunno:
I used to have a 7.3 and I had a diablo sport preditor for it that had an altitude file, helped a ton when we would get above 10,000ft in Colorado.
No Problem Here
The powerstoke has a Barometric sensor to tell the engine at what altitude it is running at.
You may have had to adjust the older IDI's but not the new ones.
Edit: BARO Barometric Pressure Sensor
An analoge device that measures Barometric pressure which allows the PCM to compensate for altitude.
Thanks for the info. Looks like I will go with a diablo predator programmer. Just looking for the best way to improve the fuel economy when towing my trailer.!:thumb:
1 - 7 of 7 Posts
