1 - 20 of 35 Posts
· Registered
Discussion Starter · #1 · (Edited by Moderator)
Hey all, with the price of steel and lift blocks I figured I would just make my own.
I drilled locating holes in top and put some strong lag bolts in the bottom for the head to locate on the spring pad
You can see I cut them long for extra stability so it should be fine I think?
Bicycle Automotive tire Bicycle part Tire Bicycle tire
Putting in the ubolts and plates soon, let me know if I should make any other improvements while I am at it.
Also, I think it was just #2 pine or whatever HD has. Should I have gotten like #1 or maybe prime?
· Administrator
· Premium Member
Ground contact lumber. You want to make sure the electrical circuits have a good ground.
Reactions: Calif250
· Registered
Discussion Starter · #17 ·
Here is a better view, needed to mock up my rear ride height to determine driveshaft support bearing spacer thickness.
Also mocking up the traction bar to make a xmember so needed driveline angle before I could get that set.
Automotive tire Bumper Automotive exterior Machine tool Gas
· Registered
Discussion Starter · #20 ·
Nice structural electrician tape! What are you building ?
I am a 1 guy show here. Plenty of zip ties and tape when I need a 3rd or 4th hand.
Got an extra 10.25" built on the bench a few months back. Yukon grizzly & 4.56 gears. Barnes4x4 truss, Ruffstuff traction bar.
All hooked up on my 1995 7.3l CCLB with 2015 springs & Skys drop hangers to reduce block size.
1 - 20 of 35 Posts
