1 - 11 of 11 Posts
Desert Shield/Storm Vet
They are the same other then the filter. You have the regular filter then the pro guard 7 that filters better and then a dry filter that doesn't need to be oiled.
so should i go for the dry? or is oiled better?
The oil will filter better because the oil will grab smaller dust particals
ill check it out
I went with the dry filter on mine but its just because I hate oiling filters, you can always upgrade just the filter later too. And you can also run a prefilter on it for a little extra filtration.
Discussion Starter · #7 ·
What do you mean by prefilter? Where does that go in relation to the intake tube?
A prefilter goes over the filter, like putting a sock on your filter. They show them on AFE's website and I know a couple of guys that just used a pair of their wives pantyhose for prefilters. I use them on my atv's on top of oiled K&N filters just because of the extreme environment they are in.
With the dry filter you just wash it and let it dry out then reuse it. With the oiled filter you just reoil it after you clean it, usually in a special solution. You will find arguments both for and against either filter and it really comes down to a metter of preference and intended use. If I was running in a dusty environment I would use the oiled filter myself. Check AFE's website for micron rating on both filters, they might be the same but IDK.
Discussion Starter · #10 ·
Cool thanks for the help
Your welcome.
1 - 11 of 11 Posts
