1 - 2 of 2 Posts
Hi guys and gals,
03 73 Excursion 4x4 limited
Just noticed that the brake pedal is not moving with the fuel pedal.
I sprayed it down real good with WD-40 and helped it slide back and forth several times.
Then I sprayed some dry lube on it and let it set for an hour or two then came back and it's still only moving about 1 in if I don't help it and then it makes the clicking noise almost like a gear is not engaging somewhere.
That tube looks like a servo of some kind, could someone confirm?
Are they easily repairable?
Sent from my E6810 using Tapatalk
Discussion Starter · #2 ·
Found a video on the throttle pedal, but not the brake. And that video was just a total swap. Easy peasy. The brake pedal does NOT look that easy.
Any help would be appreciated.
From a couple of other videos, it looks like there is a plastic gear in there that eventually cracks and then it only moves a small amount until that crack gets to the worm gear, then it stops.
1 - 2 of 2 Posts
