I wanted to start this thread to begin a discussion on adding the OEM Sync system to ’08 trucks which have already been upgraded to the newer harddrive based Nav. system.
Thanks to a fellow member (53Willy) I just got the new nav system installed in my 2008 F-350 King Ranch and I love it. Now I want to get the Synch system installed and thought that I would start a thread here to share the information I learn as I go. I will be updating this thread regularly until the project is finished at which point (assuming I am successful) I will summarize the entire project with step-by-step instructions (including part numbers and suppliers) for completing the project.
So here is where the project starts:
The project truck is a 2008 F-350 King Ranch. It came from the factory loaded with the Nav system and the audiophile sound system. The truck is a job 1 truck which did not have rear camera as an available option but the OEM tailgate camera has been added and displays on the new nav system. I have also added a front bumper camera and will be adding the lockpick module to the new Nav system to allow use of both cameras. With the use of a couple of upfitter switches I will be able to display either camera whenever I like (regardless of what gear the truck is in).
The new Nav system that was installed in my truck, came out of a 2010 F250 King Ranch which had all the same options as my truck and also had Sync. I also already have a Sync module that came out of a 2010 F-150. I hope that the two units (the nav and the sync) both being out of 2010 model trucks will mean that no programming will be required (so far none has been required for the Nav system).
At this point I still need to figure out what wiring harnesses will be required to connect the Sync module and will probably also need to change out the right side steering wheel buttons.
So let’s get started…
First I think I will need to get my hands on the interior wiring diagram for a 2009 or 2010 truck as well as one for my 08 truck. I will also need to figure out which steering wheel switch is required (there are several version of this switch) to activate and control the sync system.
I think I can work with my local Ford dealer’s parts dept. to figure out what switch I need but I have no idea how to get the wiring diagrams. If anyone has any info on how I might get my hands on the wiring diagram I would greatly appreciate hear about it.
More to come...
Steve
More to come...
Steve
