1 - 2 of 2 Posts
I've looked and looked. Anyone able to tell me if I can use any ACM out of a 2013 to 2016 superduty? I have a 2013 F-350 King ranch. It has all radio options and nav. My ACM is Dc3t-19c107-cd . do the ones out of 2015 and 2016 work in my truck if I flash AsBuilt data? The Part numbers are different. Those are EC3T-19C107-CG.
I also found a TSB that states my ACM can be replaced with EC3Z-18C869-CE but definitely can't find that one. Everywhere shows discontinued.
My ACM throws a fault code but I was able to pull data from it. I already tried updating and pulling fuse. The fuse helped a few times but now it's out and it's screwing with the HVAC module. Right now all my radio does is tune to lowest AM station and allows CD and Bluetooth. Nothing else.
Discussion Starter · #2 ·
In case anyone else wonders. They are compatible, even with the different part numbers. I did have to program new ACM, noticed I had no blue tooth, but now it's working as it should
1 - 2 of 2 Posts
