Hello All,
This subject has appeared before but not exactly like mine. Today when I started my truck all seemed fine; however, when I press on the accelerator the RPM's do not change - no response. The RPM's in idle seemed a bit high between 1100 to 1300rpm. From what I have read, the truck is in 'guardian mode'.
What has changed? The batteries were a bit low unable to start two days ago. So yesterday I charged the batteries to 100% capacity. This morning, when I took the chargers off, the truck started without incident. Again, the accelerator was unresponsive. I placed the truck in 4WD Low and moved it out of the way and hitched a ride to work. From what I can remember, all the gauges were working correctly and the Check Engine Light was OFF.
When I get home this evening, what should I check? I've seen that the ICP Sensor or the IPR Valve can cause this problem. Where are these located and how can I check?
Summary:
2004 F350 4WD (SRW) 6.0L
Mileage: ~139,000
Idle: higher than normal but smooth
Problem: accelerator not responsive whether in Park, Neutral, or Drive
Any and all feedback will be greatly appreciated.
Thank you,
Summary:
Mileage: ~139,000
Thank you,
