With the other issues I had I kind of forgot about this one.
AC seems to work ok until it gets 90's+, then blinks out. Compressor not running.
With the AC switch on (when compressor is not turning on);
pressures about 115psi L&H.
FORScan showing with (ac working or not);
"ACC On Air conditioner compressor cycling switch
ACP OPEN (OK) A/C pressure switch
WAC/ACCR On Air conditioning clutch".
Does this mean the compressor clutch should be engauged but is not?
When the compressor was turning on, at around 1800rpm, I believe the high side was going up to about 375+or- (hard to tell through the windshield) & the low was dropping to about 20-25 then cycling off.
