Well my ABS light is going on and off now. It's been doing it for about 4 weeks. There are no codes that I could find. What should I be expecting the problem to be? Ford looked at it and was saying something about a sensor in the hub. Also too I have noticed when making a left turn at full crank I'm getting a rubbing noise. I don't think it's my tires rubbing but it might be.
International Threat
ABS line going down to your hub needs to be replaced. You can use AE to determine which one it is or have Ford tell you. It hooks up at the frame and plugs in on top of the hub with a small bolt to hold it down.
Does the hub need to be disassembled to replace this line?
