First post on here. Got an 04 6.0 (obviously) and I'm getting an abs light with no speedo and truck runs weird. This only happens when the truck is sitting in the sun. It throws p5000 code which is vss and I've replaced it. Any help would be great. Thanks.
The VSS you bought could be bad or trace the wires and see if one is broken or chaffed. Also check all your ABS sensors behind each of the wheels. Could be a broken wire or bad sensor.
I don't know about in these trucks, but most of the time when a speedometer doesn't work, its because there is a wire inside of a rubber/plastic tube that runs to the transmission from the speedometer and over time the wire will break or chaffe and not spin the speedometer properly or only work sometimes.
