1 - 7 of 7 Posts
My abs brake light is flashing 16 or could be 15 times and stops and does it over and over while driving. If I start the truck, It stays off till I hit the brake. Any ideas what that means?:dunno:
97 Ford F350 Powerstroke 7.3
If the abs is blinking it might be setting a code. Might try to pull them to see if there is anything. Other than that I'm not sure, Could just be the VSS or the abs unit itself...
Actually the rear center top of the rear axle ABS sensor wiring tends to corrode then break, Since its only protected by a simple plastic (come fill me up with road debris)loom, this is the first place it's going to break.
I have a '97 and the ABS light used to blink 10-15 times and then stay on; On my truck the issue ended up being the ABS valve (on the frame fds). I can't remember if there were one or two sensors there, but it never leaked. I also noticed a bit more pedal when it was replaced. Give it a look.
My Abs light is on constantly on my truck , its a 2001 4x4 psd , what is it ?
You've got a broken ABS wire, likely at the rear diff, top center.
A blinking ABS light indicates a malfunction of the ABS unit itelf.
I just wanted to say thanks to this forum and the previous poster! I'm not one who's into forum much. My ABS light came on today after driving on some DOT #1 stone and I thought the worst. Being a Ford mechanic 10 years ago I saw how expensive the ABS system can be to repair. After searching this thread out, a simple continuity check, and later a firm tug on the wire the weight on my shoulders was lifted. Thanks again for making my day!:)
1 - 7 of 7 Posts
