I have read a few threads here about setting the TMPS, or changing the setting range to keep the tires from working as over inflated. I found this info on another forum used for several Ford Models. It looks like this method allowed for the programing of the tire's PSI lower limit. Also this method does not use the handheld programmer. Getting the TMPS system into program mode is a bit different but the rest of the functionality looks the same:
No need to go and buy the TPMS learning tool.
1) Make sure your tires are inflated to the recommended psi. Mine is 40psi.
2) Turn ignition to the on position. If you have a push button start, push the start button without pressing the brake pedal.
3) Push the hazard light button 6 times. The horn should honk and you should see "Train left front tire" in the LCD display between the tach and speedo.
4) Release air pressure in the front left tire until you hear the horn honk. The LCD display should now read "Train right front tire".
5) Release air pressure in the right front tire until you hear the horn honk.
6) Repeat for the the right rear tire, and then the left rear tire.
7) You should now see "Training Complete" in the LCD display.
8) Fill your tires back up to the recommended pressure.
