1 - 5 of 5 Posts
Does anyone make a 4 pillar pod that actually takes the place of the factory pillar instead of installing over it? They make them for the Dudges and I would prefer to install a complete replacement instead of installing over factory pillar. Thanks in advance.
Mine is from autometer and it replaces the factory trim. I do not know if they make a 4 gauge pillar.
No one make a "replacement pillar" for the Fords. They are all designed to be mounted/attached to your existing pillar. You remove the grab handle and attach them with plastic push pins.
1 - 5 of 5 Posts
