so the local auto part store has a do it yourself a/c recharge kit that says works on most vehicles. just wondering if anyone has tried one of these kits? does it work, or is it worth taking it somewhere to get it recharged? getting warm here and a/c doesnt get too cold anymore. thanks
i would like to know too
They work fine if you have a leak and just need to top off your R-12 or R-134a. Your A/C system is a closed loop, so if it isn't quite as cold as it used to be, the freon is escaping through some sort of leak. In that case, buy the kit with the dye in it to try to determine where it is escaping from. Make sure you don't overcharge your system.
good info here. i already found the leak and fixed it, so i am going to get the kit today and give it a shot. its only $40 so i figure its worth a try. i will report back with the results. thanks guys:thumb:
How empty was your system? You well be better off going and have your system pulled to a vacuum to get the air out of the system then recharge it it well cool better. with air in the system it well not take a full charge.
They sell this stuff at a lot of stores where I live, its called red-tek 12a. They have recharge kits, dyes, and sealers for A/C systems...Never tried it so I can't say how good it works.
RED TEK - Products
