I have a 2005 F-250 XLT CCLB 4X4 with automatic transmission. My A/c last year started blowing out the defroster all the time. I took it to the dealer and they replaced the vacuum pump. A couple of weeks ago, I bogged down in some river gravel and put my four wheel drive into gear with the hubs and switch. Immediately my A/C went to my defroster and wouldn't switch until I turned it to vent and waited for it to blow through the vents. Then I put it on A/C and it stayed. Now every time I start it, it blows through the defroster until I put it on vent and wait. It's been 105 all week and after working outside all day, I want the A/C to work. I don't get near the air velocity that I did have and some of the air is getting stuck between the defroster and vents. Any help will be greatly appreciated as I just went out of extended warranty. Thank you :dunno:
Mine does similar things when i start truck it blows defrost for like a minute or so then to my vents. If i use 4wd and the hubs lock it does it longer for a while . I think my hub seals are starting to leak so it takes some pressure away from the air ducks causing this to happen. Yours could be a similar problem.
My hubs are back to auto and I still have this problem. I think it is a control issue as today it didn't blow real cold for a while and then it did. I will research the manuals as I haven't had much help here. Maybe the other forum will help????
If your hub seals leak then it effects your vacume presure. Also another great forum is Ford TRUCK ENTHUSIASTS great bunch of people there
