2014 f350 Compressor is being commanded off and back on continually. AC high pressure reads normal when running on a guage set. 105* day (Phoenix) guages read 40ish and 325ish (trying to remember exactly what they read). Biggest issue is at the same time Autoenguity shows 625ish on high pressure gauge. Even after an sitting for a couple days, high pressure switch on scanner shows 375psi with engine off! Gauge shows somewhere around 100? Have replaced high pressure switch as I figured that was the issue. New switch shows the same readings.
Have a new gauge set coming today to back up my old guages to ensure that is not the issue. Can understand why such a high reading after sitting for day and why such a disparity between guages and 2 different switches? Any other ideas?
