It's most likely your actuator. There's two components that run the speed. I had the same issue and was going to replace the main unit and the actuator, but I had to disconnect my batteries for something and it corrected itself. It's behind the passenger glove box--easy fix. Buying from Ford was like $150 for both parts. From Rock Auto, much cheaper. Hope that helps.
