How can you find misfiring cylinder that passes balance test????
L Layto15 · Registered Joined Oct 12, 2012 · 2 Posts Discussion Starter • #1 • Oct 12, 2012 How can you find misfiring cylinder that passes balance test????
timmyboy76 · Registered Joined Aug 12, 2010 · 1,888 Posts #2 • Oct 12, 2012 If understanding correctly, remove the vc's, and fire up motor. The injectors should discharge oil from them. Any that dont, arent passing.
L Layto15 · Registered Joined Oct 12, 2012 · 2 Posts Discussion Starter • #3 • Oct 13, 2012 Thanks for your help!!
