1 - 9 of 9 Posts
i have a 99 f350 5.4L gasser and recently its shakin like a motha f*
i thought at first it was my alignment. but then i stopped the truck. and it just shakes. im positive its something with the motor. if i dont give her a decent amount of gas when accelerating it shakes like crazy. its not as bad when i get going over 60 though. :/
any ideas?
I would guss a bad coil pac, its very common on those motors.
PMR = JUNK
Definitely something with the ignition system. Plugs, wires, coil pack. Id probably just replace them all.
It sounds like electrical but could it also be an injector?
PMR = JUNK
Its possible i guess, but its really most likely the ignition system needing a tune up.
you can get coil pacs from summit racing for $20-25 bucks ea
that and a set of plugs should make your truck run great.
PMR = JUNK
Don't forget wires too though.:nod:
PMR = JUNK
there coil-on-plug, no wires just plug boots
Oh, gotcha.:thumb: Didn't know that. Im not the most knowledgeable on the technicals of the newer ford gassers.
1 - 9 of 9 Posts
