when cold runs strong with good throttle response , but after it warms up it starts running rough . sometimes it doesn't happen . I have changed cam sensor , fuel filter . checked oil level ,its ok( if low on oil injectors wont have enough pressure to work properly .anyone run into this before ?
Any codes? sound different? whats boost like? any more info would help.
rogueknight
I checked for codes no stored codes , changed fuel pump in frame , changed oil and filter just to be sure.:(
Did you check the codes while concern was present? The inner connectors are bad about coming partially apart after warming up but it will set codes when doing the buzz test. High to low circuit codes on which ever bank its related to. Wait till it starts doing it then do a buzz test & listen to the inj's buzz. All should be loud unless theres a circuit concern.
