21 - 26 of 26 Posts
Did not get any fuel pressure from the fuel bowl.
You have no pressure, or you haven't gotten a reading?
Ok so you've done a Lot of work I see. But after all that work, it ran well for some time? None of these problems immediately followed any of it?
That pic was during cranking
No, you show 2300psi at 184rpm, the other pic shows 2900psi while your rpm is 0
The truck died when driving. Had intermittent stop start for a bit. After it died we put a heat gun to it and two cylinders weren't firing. Decided to replace those two injectors. That didn't work so then I started at the tank and worked my way up to the front. But still no luck. This was a year ago.
the CPS i have is a motorcraft part like recommended.
idk anything would just go bad after a year of sitting if they are supposed to last for quite awhile.
I must have taken that screenshot right when I stopped cranking.
I didn't get a reading from Schrader valve port on back of fuel bowl.
hutch gas tank mod
universal frame mounted water separator filter
new frame mounted fuel pump
new fuel bowl heating element
Leave the cap off the filter and key on -- is there fuel in the housing? does it fill quickly?
Pressure at the test port is an important step in figuring this problem
I had this same problem (crank no start), on a 2001 7.3 that I had. It died on me one day in the middle of the road just died and that was it. I had white smoke coming from the tailpipe when cranking. Pulled it home and I checked out everything that I knew would keep it from starting and everything checked out fine. I had the charger hooked up on med. to keep the batteries up while cranking and noticed that it developed a power draw and my battery voltage got way high like 15.5-16v and then it would drop as soon as you shut the charger off and be dead in under a min. Ended up the one battery had a dead short in the cells and that ruined my PCM. Replaced both batteries and the PCM and that solved my problem. Got the new PCM in and the truck fired right up.Not sure if the batteries went bad and ruined your PCM but figured I would share my experience. I know how frustrating it can be. Best of luck to you.
thank you for the detailed response.
So as of today
WTS light comes on with key
The tachometer registers when cranking
Fuel bowl fills quickly when key is on
New pump on the fuel rail
No chip or tuner
New icp
Have tried to start with pigtail supplied with 12v from battery
New IPR and new plug
previously installed after initial shutdown
Two new AB injectors passenger side rear two cylinders
New stock turbo
New EBPV
New/Used Hpop
New Hpop lines
New Undercover gasket harness
New IDM
Power probed IDM plug and OHMd injectors and glow plugs
All glow plugs have been removed and tested
Glow plug relay puts out 11.5v during last test
New Batteries
Dropped tank and removed screen filters
Installed longer draw straw and longer return line called a hutch mod
Installed universal filter housing on frame
Installed water separator on housing and rain new fuel rubber fuel lines to frame mounted fuel pump
All diesel rated rubber fuel hose used with pipe clamps
Havent done a compression test yet due to no adapter
Will do fill Hpop system with air again and look for leaks.
Have not had injectors tested yet.
PCM faulty?
thanks again
"New IPR and new plug"
DID YOU CHECK THE WIRES ON THE NEW IPR PLUG?....WERE THEY ALL CONNECTED (SPLICED) CORRECTLY?....
HOW MUCH FUEL DID YOU PUT IN THE TANK AFTER THE HUTCH AND HARPOON MOD?....
"ALL" FUSES TEST GOOD?....
21 - 26 of 26 Posts
