1 - 2 of 2 Posts
Hello, i have a 99 7.3 & can’t get the 4x4 to engage, it has manual hubs in it. The relays check good, there is no power to the electric switch inside the cab, & no power at the transfer case motor where the two wire plug goes into the motor. The motor on the transfer case is new also. any help will be appreciated!
2000 Ford F250 SuperCab 4x4 7.3
Hey There Strokin'
I'm a new guy with these diesels. But not soo new to the b.s. associated with these trucks. And danged near all the vehicles I've worked on. Number unknown. But anyways, start off simple my friend. Check your fuses inside your drivers side a-pillar fuse panel. Should be accessible under the left side(drivers) dash. Couldn't tell you the number(s), but might as well check them all.
If all good there, check grounds.
Ill check back every so often to see if you made progress. Working on my basket case currently.
1 - 2 of 2 Posts
