1 - 7 of 7 Posts
what do i need to do or change to put a 97 engine in a 2002 i have a full fuel system a t4 mount turbo and some other stuff but what do i need to do to make this work any help?? will this stuff be compatible
IIRC, about the only thing that will work is the block, and you'll have to swap all of your accessories onto it..
Sent from my DROIDX using AutoGuide.Com Free App
Same motor, but not the same. Different ecu's, hpop, sticks, tranny, etc.
you will have to swap:
turbo, hpop, injectors, plenums, and plug the hole in the valley. 19mm freeze plug works.
^Hole in the valley from what???
from the fuel pump
ah yes the weak mechanical pump :doh:
1 - 7 of 7 Posts
