anyone know any tricks here? the truck won't shift into park but i don't think it is the transmission. The steering column feels very sloppy and you have to feel for the gears instead of veiwing the gear indicator.
the guts of your steering column my be falling apart inside.
Full A-Team Member
try tightening the 2 small bolts on the shift assembly under the column, may just fix it, it worked for mine, 5 min fix
or the shift cable might be stretching along w/what they said... they wear out over time
