Hello Everybody!
I recently purchased a 1996 F350 CCLB with a 7.3 and a 5 speed manual. It has 234,000 miles and was pretty much stock when purchased.
I decided to purchase this truck because:
A. I really like the OBS crew cab for family trips.
B. I like the 5 speed.
C. It has a 4:10 gear ratio which is great for towing.
D. I think the 7.3 Powerstroke is a great motor.
Things I have done to it so far.
1. Diamond Eye 4" Exhaust (3.5" Down Pipe)
2. 6637 Intake with Riff Raff Sleeve
3. AFE Rear Differential Cover with 75w-140 Synthetic Fluid Change
4. New Ball Joints, Front Wheel Bearings, Front Axle Seals, Front Disc Brakes, and Front Axle Fluid Change
5. New Coolant Cap
6. New Oil Fill Cap
7. New Injector O-Rings
8. New UVCH's
9. New Glow Plugs
10. New CPS
11. Unplugged EBPV
12. Oil Change, Fuel Filter Change, and Coolant Additive
13. CCV Mod
14. Riff Raff Intake and Plenum Boots
15. New ICP Sensor
Problems Remaining:
1. Leaking Up Pipes
2. Slow Turbo Spool (Doesn't come on till 1900 rpms)
3. Cranks slow when starting
4. Idles a little rough when at operating temp
5. Needs Clutch Replacement
6. Steering is sloppy
7. Smokes bluish white smoke when cold started. Smokes a little black smoke at WOT when hot.
8. Blow by amount seems normal for an engine of this vintage.
So...I've got a bit of work to complete on it before I haul cows this winter. I'm planning to fix most of these issues in the next 3-6 months. Here's what I've ordered in to prepare for the "GREAT REPAIR" as I've labeled it.
1. South Bend Clutch Kit. (350 hp capable...single disc)
2. Fast Spool Turbo from Ron Holland. (1.0 A/R exhaust housing)
3. EBPV Delete Outlet and Pedestal
4. New Stock Fuel Pump
5. High Pressure Oil Rail Cross Over Pipe
6. New Fuel and HPO Seals, O-Rings, and Sleeves
7. New Melling LPOP
Other things I hope to order for this repair segment:
1. Riff Raff Bellowed Up Pipes (They're out of stock for a couple of weeks)
2. Redhead steering gear box
3. Borgeson U-joint Steering shaft
4. A good set of shocks
Other things for next repair segment...(When I get some more money.)
5. MAYBE a set of stock injectors as I'm fairly certain that these have a large amount of wear with 234,000 miles.
6. MAYBE a 17 HPOP...gotta check pressures and duty cycle
7. MAYBE a good quality starter.
So, anyway, there's a description of what I'm doing. Please feel free to offer any suggestions or thoughts. I would appreciate any advice you might have as I have a fair amount of experience with these trucks but I know a lot of you have much more experience/knowledge.
Also, I have a couple of questions:
1. Should I replace the rear main seal?
I have read a lot of articles that say, "Don't Touch It!!!!" BUT.........it seems kind of foolish to be right there/ have access to it/ not replace it. It's not leaking to my knowledge at this time but it does have 234,000 miles on it.
2. Should I replace any of the seals on the ZF5/Transfer case while I have them out?
I think there is a little seepage of Transmission fluid from somewhere but nothing major.
3. Should I replace the O-Rings on the rear fuel rail plugs and HPO rail plugs while I have access to them with the tranny out?
4. Should I replace the water pump as a preventative measure while I'm changing the LPOP? It's the stock one from the factory.
5. Should I replace the wear ring on the damper when I am installing the LPOP? It's not leaking at this time.
I will probably have a few more questions as I work my way through this. Thanks in advance for your comments. I appreciate all the contributors on this forum.
Kind Regards,
Josiah
5. New Coolant Cap
6. New Oil Fill Cap
8. New UVCH's
9. New Glow Plugs
10. New CPS
11. Unplugged EBPV
13. CCV Mod
15. New ICP Sensor
Problems Remaining:
1. Leaking Up Pipes
7. New Melling LPOP
Kind Regards,
Josiah
