so I swapped the engine in my 96 f350 this spring and the first fire it wasn't firing on the right side I used the engine harness from the original engine first i checked the valve cover gaskets and they didn't look burnt or anything tested them for a short and didn't find any next I pull the plug from the idm and ohmed the harness and injector solenoids and got 3.4 ohms from all eight. next i check the ground Sheild wires and they come back good so i replaced the idm and the same issue next i replaced the engine harness with a known good one that was unmolested issue still exists. so i tried another idm still no fix. i tried replacing the four injectors with four out of the old motor that i know worked still no fix. i checked the ground on the radiator support and the inner fenders and they are good. my question is can old codes keep the idm from working properly or is there and communication between the pcm and the idm the other thing i notice towards the end the tach doesn't move till it fires and u got to crank a long time before it fires. no smoke what so ever. from what i was told it ran good before pulled and that it was a ford reman with 160,000 miles on it. Any help would be appreciated thanks
