To check HPOP pressure shop manual says to disconnect one of the HPOP line fittings at head, then the other and see if it starts & check pressures...
What size is the plug? or where to get if its a special fitting?
Already have pressure guage plumed in, so i don't need the special fitting / adpater shown in shop manual.
Electrical Ogre
If I remember correctly, it's a #5 ORB fitting. You can get ORB to NPT adapters at Princess Auto in their hydraulic section.
Have narrowed it down to #5. Looks like tight fit to pull injector out?
Will i have to drop the motor mount to gain clearance?
