1 - 20 of 20 Posts
Hey guys need a little help on this one. Ok my truck has developed a problem i change the manual tranny fluid about 4 days ago. and now my truck grind when i shift from 2nd to 3rd. and it also grind when i down shift from 4th to 3rd. Need help is it my clutch or is it the synchros. :dunno:
Read post on other site, synchros.
ya i read it on psn i hope its not that. you have any idea of how much a rebuild cost
bump..... need to figure this out
what fluid did you put in?
Electrical Ogre
It's supposed to be synthetic mercon, not sure if it makes a difference or not. The ZF uses friction cone syncros, so once they wear down, they're shot. A syncro kit is around $400.
What did you figure out?
im going to try differnt fluid this weekend have been just baby in it trying not to grind it in 3rd hope i just used the wrong oil.
so here's the latest with my trucks ZF5. so i changed the oil today to amsoil full synthetic and guess what same thing is still going on. so now i am to the conclusion that it needs a rebuild i am going to take it to a tranny shop this week to get a second opinion it, :dunno: also alberta7.3 do you have a site or a number that i can get to price out a rebuild kit. is that a total rebuild in parts. also since they will have my tranny out I'm going to replace the clutch. what company should i go with would like to here is people opion on the differnt makers such as luk, south bend, centerforce, valair, etc thank you guys for all of you advise.
Electrical Ogre
Manual Transmission Parts
They list practically every part, and the syncro kit is 189.95
You'll probably have to get a snap ring kit and seals from ford though
Might aswell replace all the bearings while your at it. Having to get a new input shaft due to a worn bearing is expensive.
Discussion Starter #13
looked in to a complete rebuild and it is about 1200. i think that is the way i going to go
Electrical Ogre
That sounds like a fair price. Wreckers usually want $12-1500 for one that's used with a questionable history.
Discussion Starter #15
i think i will have them put in a new clutch also. what maker would you go with bill
Electrical Ogre
I'm running a Luk which seems good. Valair clutches are supposed to excellent.
Discussion Starter #17
That is what the guy at the tranny shop i spoke with. said he likes is LUK. so that is probably what i will go with also should i up grade to a single mass flywheel. and also a higher HP rated clutch even though my truck is basically stock right now. but am going to up the hp as soon as i get the dam tranny prob fixed
I'd get the solid flywheel and a higher HP clutch, that way you can beat on it later when you really want to.
drivetrain.com has a complete rebuild kit for 318 with syncros and a rebuilt tranny for 1100
1 - 20 of 20 Posts
