I wanted to get a second set of tires and rims for winter and summer. I found a decent set for sale. The guy said the rims and tires where on a 95 f250 and he didn't think the bolt pattern was the same on my 03 250. Good deal if I can just balance and bolt on, not as good if I have to have mounted on my rims.
Bolt pattern is different, those rims won't fit. Good luck tho
The '95 is a 6.5" pattern the the '03 is a 170mm. I believe the switch happened somewhere in mid '99 but I'm open to correction on that. You can buy adapters to make them work but for what they cost you may as well put that money into new correct rims IMO.
