1 - 7 of 7 Posts
Does anyone know if the frames on a 95 f350 cc 2wd and the frame on a 95 f350 cc 4wd are the same frame.I am wanting to put the 4wd components on my 2 wd without changing the frame.Do the frames have the holes for either coil springs or leaf spring setup?Thanks
I was under the impression everything is direct swap. I know I can direct swap f350 axles into my 250. As long as the wheelbase is the same I see no reason you cannot swap drivetrains.
Basicly I am wanting to make my 2WD a 4WD.
That being said, I know a guy who took a 250 4x2 and basically made a 350 4x4 and hasn't had any problem with twisting the frame.
Do you know if you have do drill the 2wd frame for the mounts or are they pre drilled(universal holes)?
1 - 7 of 7 Posts
