1995 Ford F-250 Powerstroke. 7.3 Diesel!
Extended cab, long bed
4x4
5-speed
A/C that will freeze you
198,xxx miles
The good-
New clutch (throwout bearing, resurfaced flywheel, flywheel is solid wheel, not dual mass!)
New Rear main seal.
Newer glowplugs and under valve cover harness
Newer starter.
Newer Batteries.
Helper bags in the Rear suspension
straight piped exhaust
home made cold air intake.
NO RUST!!!
Meaty tires
the bad-ish-
Just replaced the rear main seal, and still oil leaking.. i think its coming from the top of the motor but havent checked yet. thats the only problem with this truck!
this is a good running truck with just a small issue. with a little tlc it will be back to perfect. it will pull anything you put behind it! very well taken care of its whole life. will easily last another 200xxx miles!
$5,500 O.B.O
No lowballers..
:worthless[1]:
Also where you located?
