so i thought the idm may be my problem but i discovered the number 8 maxi fuse was missing now i have power to pin 14 on the idm harness. tried cranking and it finally starting squirting oil out of the injector and dumping tons of white smoke out of the exhaust. it has a new cps. i had another stroker jump starting for 2 hours and cranked for 20-30 seconds and then wait 15 minutes to let batteries charge up. cranks really stong and tries to turn over just wont quite make it.
is there anything i should check. maxi fuse 22 is good and i took the fuel bowl heater out. could it just be that i had the oil and fuel lines off and the injectors out and its trying to clear all the air out of the lines and what not. last i did injector orings it took awhile to turn over but i dont remember taking 2 hours maybe i just have a bad memory lol. any input would be most appreciated
thanks jim
thanks jim
