So I was driving and stopped for construction when I started my engine I smelled some fuel. I kept going and the smell never went away. So finally I got worried and stopped. I think it’s the fuel regulator after the fuel filter where each line goes to the injectors... it’s leaking like a leaky water faucet. ... I’m guessing it’s a connection. But I’m wondering if this is common and if people have seen it before. Thanks
You might want to have this moved (or repost) to the "Pre-Powerstroke Diesel Section" in either the "Non-Powerstroke General Discussion" forum or the "7.3L IDI (Non-Powerstroke) Diesels" forum as those deal with the IDI motors and the folks there are likely to provide the advice you need. Cheers!
Blow me to Bermuda!
You likely won't find much help on these forums for IDIs. You'll have much better luck here:
OilBurners.net
