1 - 1 of 1 Posts
#1 12-07-2007, 02:11 PM
livnlrn
Registered User Join Date: Dec 2006
93 Lx, 331 Supercharged
The car is a 1993,
with a numerous list of mods and time spent on it. It made 542 @ the wheels with pump gas. It is 100 % streetable and fun to drive. I am looking for a change. I drive it every chance on a nice day. It hasn't seen any rain or bad weather.
Will not be disappointed with car!!!!
Here is the list of what the car has. I am sure I forgot some minor stuff.
High Performance Sportsman 331 cu
Sportsman block
ROSS Pistons (8.5 – 1 compression)
Steel crank
4340 H-Beam rods
Australian double roller timing chain
ATI Harmonic Balancer
JW Flywheel
Pat Bennett Race Cars 10 pt roll cage
5 point harness
Vortech S Trim Supercharger (Polished)
Custom computer chip with tune
Vortech Aftercooler (Polished)
HKS race bypass valve
Edelbrock Victor Jr Aluminum heads
Sheet metal valve covers (Polished)
Holley Systemax intake (Polished)
Dynamic Racing Transmission Mighty Mite C-4
TCT Race Convertor
B&M Race cooler & steel braided lines
Anderson Ford Motorsports power pipe
65MM throttlebody and EGR spacer
80 MM Pro M Mass Air meter
Jet Hot Ceramic Coated Kooks long tube headers
55 lb Siemans Deka injectors
Aeromotive complete Competition fuel system
Weldon 2025 fuel pump
40 & 10 micron Weldon filters
Weldon Voltage controller
1.6 roller rockers
Hardened push rods
Crane lifters
3:73 rear w/spool, c-clip eleminators, 31 spline hardened Moser axles,T/A girdle w/stud kit, extended wheel studs
Front Tubular K member
Front Tubular A arms
Lakewood 90-10 front struts
Lakewood 50-50 rear shocks
Coil over kit
Hal 14/175 springs
Hotchkis Camber/Caster Plates
Bump Steer Kit
Light weight Steering Shaft
MSD 6 AL ignition
Accel coil
BB&K subframe connectors
METCO upper and lower control arms
Be Cool Magic Dual electric radiator fans
Stainless Steel radiator hoses
Driveshaft loop
Hurst Quarter Stick Shifter
MSD Shift light
Weld Draglite wheels
Hoosier Quick Time Pros
Aluminum drive shaft
BB&K High flow H-pipe
Moroso battery box
Flaming River cut off switch
Autometer 3 gauge cluster
Digital gauges for boost and fuel sensors
130 AMP Alternator
Diamond Cut Clear Headlights
AC Delete Kit
Custom paint with graphics
I can email specific pictures to anyone if you need to see certain area.
I have receipts and documents for well over 40,000.00 in the car.
Asking- 20,000
1 - 1 of 1 Posts
