1 - 10 of 10 Posts
hey guys new to the forum but not new to ford trucks i run a garage door business and all of my trucks are fords with lots of miles and still running stong but enough about me i just wanted to tap into you all's wealth of knowledge i have a 92 7.3 that will not start. started out just doing it when it was hot or run for quite awhile once you shut it off you had to wait about an hour and then it would start back. i'll tell you what i know so far i have fuel preesure at the fuel filter when i crank it. but i cracked the injector lines and i have no fuel there please help:bump:
BIG TRUCK, SMALL DRIVER
Check the fuel cut off solenoid on the injector pump. It could also be a failing injector pump.
:welcome1: Welcome to the ORG.!
When it wont start pour some cool water, NOT ICE COLD water on the injection pump to cool it down. IF it starts, it's time for a injection pump rebuild.
the solenoid on top off the pump is not clicking when i turn the key on anyway to bypass it or wire it straight just to see if that is the problem and where can i find one can't seem to find one localy. injector pump rebuild if that is the problem. i'm kind of new to this diesel stuff what kind of $$$ are we talking about
injection pump, injection pump, injection pump, lol, you can waste alot of time trying to figure out whats wrong , but if you have base fuel pressure put a injection pump on it
will a rebuild be suffice or should i get a new and any ideas on the best place to find one. nice truck scuffy bet that 90g aux. tank cost a pretty penny to fill.
just wanted to take a minute to thank you guys for all your help. it was indeed the injector pump still pouring coldwater over it when it gets hot until i get my new (rebuilt) pump in. that water trick has saved my life. i know it's not technically a powerstroke but i still love my old workhorse.
1 - 10 of 10 Posts
