Doing egr valve and cooler delete. Instructions says to remove upper section oe fan shourd to loose belt to remove alternator. But it looks like one piece. Any help with pics would help? Thanks.
Are you referring to this piece? Use a screwdriver to carefully detach the lock tabs.
Will that let me get to the belt tensioner
