21 - 24 of 24 Posts
that is a high stack of cribbing you got there
I can rent ya a crane for the motor swap
Nice to see a fellow mud bogger. Rangers on rocks are sweet! Just about got my 2nd build put together. Looking for a diesel C6 myself, lol. Where are you located? We gotta romp come next spring.
You should put that in the OBS pic thread!:thumb:
turbo...
everything ive ever learned about diesels is they LIVE on compression. they more they get, the better. glow plugs- pretty useless. a diesel motor runs from the combustion caused my compression not ignition from glow plugs. glow plugs just help start quicker and easier, especially in the cold. look in a dump truck or semi they run block heaters or heated heads but no glow plugs. typically over 30psi of boost and a compression ratio easily over 15:1
21 - 24 of 24 Posts
