Engine
71 block o-ringed and hydr. roller coversion already done
10.6.1 comp. 395ci
eagle cast crank
eagle h-beam rods
ross steel wrist pins
probe forged ft pistons
copper head gaskets
soild motor mounts
ford motorsports timing chain
harden oil pump shaft
comp solid roller .673/.673
comp lifters
trickflow pushrods
trickflow R heads(new guides,valves,seats) tit. retainers
crane gold rockers
trickflow rocker arm girdle
super vic 750 prosystems or 800 holley carb
motorsports blk and red valve covers
msd dist.
sfi ballencer
sfi flywheel
hi torque cobra starter
canton deep pan
130 amp alt.
Trans
******* c4 with pro brake
******* nitrous convt.
deep pan
hurst quter stick
trans cooler with 6A braided line
SUSP. front
QA1 tubular k member
A arms
coilovers
caster chambers
flaming river rack
steering shaft
drilled and slotted rotors
SUSP. rear
QA1 coilovers
UPR dbl. adj uppers
UPR adj lowers
reinforced upper and lower torque boxes
anti roll
braced 8.8 33 spline mosler axles
c- clip elimnators
1/2" long studs
TA rear girdle
4.10 gear
full spool
CHASSIS
10pt ms cage cert. til 4/2010 driver side swing out bar
mini tubed (stock streched wheel wells)
on/off switch rear mount
wheelie bar mounts (no bars)
parachute mount ( no chute)
sub frame connectors
drive shaft loop
alum ford motorsports drive shaft
alum radiator
mark 8 fan
DOWNS radiator hold down
manual brake conversion
smoked aftermarket headlights
S.O.S alum wing on rear
WHEELS
BOGARTS DRAG STAR 15x3.5 front
M/T sportsman tires
BOGART DRAG STAR 15x12 8.75bs
M/T 325/50 drag radial tires
INTERIOR
all black interior
auto meter silver face gauges in auto meter gauge cage
TACH
ELEC. FUEL
WATER
OIL
painless wiring nitrous box for 3 stages
rear seal delete
billet door handle covers
billet door lock knobs
billet window switch covers
power door locks still function
billet heater knobs
chrome steering wheel (tilt wheel)
kirkey alum. seat and covers
holcomb seat brackets
FUEL SYS.
magnafuel pump & filter
magna fuel 2 port regulator
magna fuel fuel log (2 regulator mounts)
10A braided feed back to log 8A to carb
holley reg. set up for nitrous
braided 6A feed to fuel solenoid
8A lines from log to carb
EXHAUST
2" kooks uncoated headers
3" exhaust with dynomax ultra flow dumped at the rear end
MISC.
5" bolt on hood (pinned in the front)
msd 7al-2 box
msd pro power coil
battery trunk mount
big shot NOS plate
2" adapter
