I have a 99 super duty, runs fine until a SES light pops up. After the light pops up it stalls out if it is running, and when you try to start it it just cranks. I have no code reader able to pull up the codes. Once the SES light goes away it will fire right up
Any suggestions?
I took it to a shop today and the only code that pops up is P0470 which is EBP. Would the EBP cause it to stall and shut off?
Can if the sensor is shorting out or the wiring leading to the sensor has a worn spot
