Hello
I have a 2001 f350 7.3L
Recently I have replaced the drivers side battery (which the pass. checks out fine)
and the alternator
fuel filter
serp. belt
Problem - this goes back throughout the last month - the first onset of the problem arose with when i would try to drive forward (not noticed in reverse) i would have a loss of power - regardless of how much i pushed the pedal down there would be a slow increase in actual speed of the vehicle with no increase of RPM - the first time this happened was a chilly morning - second time was middle of afternoon at 70F - so temp hasnt been a direct issue - the most recent time was yesterday - on the way to work and it was cold - it had the loss of power issue where it would slowly pull away but then when it got to a certain point (i wasnt watching so i cant indicate a certain speed or rpm) it kicked in fine then the same thing happened after work on the way home - - loss of power when pulling away then after going a couple hundred feet it acted fine - on the way home i had to stop at a few red lights and i was curious if this problem would only happen when pulling away from a stop and it drove fine then - also when going 25 and stepping into the pedal it kicks down fine - the problem only seems to arise the first time you start it up ..... until today .....
this morning i jump in and turn the key on .. wait for the "wait to start" light to go off then crank the engine and it just cranks and cranks so i wait a second then it cranks and cranks and start to turn over and chug a little then when it seems like its going to start and i stop turning the key the engine dies and makes a weird blow out sound - you hear air released - seems like turbo or something releasing pressure
I dont have a vehicle scanner but when the problem with loss of power happened a few weeks ago i take it to my local shop that works on diesels and they scanned it and there were no problems and they couldn't replicate any issues so i took it home and it was fine for the last week or two until the last two days
any thoughts?
when i only had the loss of power at take off i thought it might have been the acceleration switch/ idle validation switch thats on the pedal but after the problem this morning im thinking its something with the turbo
any help is greatly appreciated - btw this is my first diesel ive owned so if your explaining something please give a good description without any shortcuts or quick references
Thanks!:ford:
and the alternator
fuel filter
serp. belt
any thoughts?
Thanks!:ford:
