Have a 2001 7.3 installed all new glow plugs, relay, harness and it was starting amazing sat for 3 weeks went to fire it up and it needed ether and about 20 minutes of cranking to go. Ran like crap till I started it 3 days in a row and drove it a few miles. Now it runs like new but same issue 3 cranks fires, 3 cranks fires won’t start without the Cosby sauce, did every test FORScan has nothing failed. So I tore the glow plugs out and they are all operational did a out of head test on 1 on both sides (they get red hot) and tested resistance on the rest all good. White smoke trying to start only needs 1 little shot of ether then runs smooth and no issues. Pressure to fuel bowl is terrific gasket rolled on new filter and sprayed fuel 4ft out the hood. Going to buy new pressure gauge and test for bleed because it’s completely fine until it’s sat for 8 hours and fully cooled. Fuel bowls full, no visible leaks motor is clean and low mileage. Anyone have an idea of what could be culprit other than bleed back or hpop? (which I’ll be testing tomorrow) also if it is bleeding down what would the cause be? Considering injectors are fine because it would likely start at a higher idle with a cylinder filled and a shot of ether starts and runs at regular idle.
