First off, this is my first post within this forum. I am an avid Diesel "doctor" for many Mercedes diesels from light to heavy duty applications. If Im not driving a MB diesel, I am driving a powerstroke and right now I have abit of a problem on a truck I havent had long.
Details in Chronological Order:
-Nearly ran out of fuel when in a foreign part of region, replaced fuel to 1/2 tank
- Major loss of power, poor shifting, etc. since before making it to the fuel station and continued after refueling.
- I noise of a misfire and injector nailing is present with the loss of power. Sounds like its runing poor but idle is good at the tach.
- No start next morning. Found no fuel in Fuel Bowl.
- Cycled Key many times and found fuel in bowl did not prime.
-Added about 1/2 G to fuel bowl while trying to start.
- eventually started using a spec of ether. Fuel now overflowing from Fuel Bowl.
- Tried to purge air by opening fuel bowl at top and bottom while engine running.
- Still running rough w/ no power.
-Unplugged ICP sensor w/no change in idle.
-IPR seems Ok.
Right now I am considering tht the mechanical lift pump is going out. Its a job ive done on a previously owned truck that Im familiar with. I have not changed the pump yet because Im wondering about the fuel sending unit on the fuel tank along with the tank screen/pickup. I am also wondering about blowing out the hardlines w/ air and any tips or tricks you can throw my way. This is my daily driver now.
I am eager to be apart of this community as it seems like im in a great place.
Best,
Ninja_Cowboy
-IPR seems Ok.
Best,
Ninja_Cowboy
