Hello guy's! I have a 01 ford 7.3 litre with a manual transmission. I recently install stage 1 injectors in it. When i let it warm up for a bit and take off it is really slow to build boost and once it finally gets up to operating temp it will then build boost but still not as fast or as much as it did before. It has a bd turbo that is only a year old , cold air intake 4" turbo back exhaust and a programmer. It was also doing this right before i upgraded my injectors. My hpop pressure is fine also, I checked the pressure with my scanner. Any help would be appreciated. Thanx for the help
