1 - 8 of 8 Posts
Howdy!
I just put a wonderful 7.3 on the road. It's a '99 F-250, reg cab, long bed. I have a 1500 pound welder generator mounted inside the box. I added two extra springs on each side in the back. She sits nice.
I'm having major fuel mileage issues. For 130-140 litres of diesel, I'm barely getting 400 kilometers per full tank of fuel.
Mind you, I deleted the muffler (four inch pipe all the way down), and installed an Air Raid cold air intake. The previous owner told me that I should be getting 800 kilometers plus in the winter, and a thousand kilometers plus in the summer months.
Something ain't right. I don't know what to do.
FYI, I just changed all glow plugs, glow plug relay, valve cover gaskets, and block heater.
If you dudes have any advice, I'm all ears.
What type of mileage should I be getting?
Thanks!
woah.......thats about 7miles per gallon, i get about 15mpg with a 99 Extended cab long bed. So a little over 900 kilometers on 38 gallons of fuel (143liters) a little less in the winter like now.
Well, how do you drive it? How fast? How much idling? What RPMs do you run?
WelderDude, where are you located?
Thats pretty bad mileage
I'm getting 16.5 in a sclb with a 4 inch lift and that's letting it run for 5-10 min in morning before I leave,avg 30 mile trip to work or store.
Your mileage is about half of what it should be... I think you have a massive boost leak somewhere.
1 - 8 of 8 Posts
